Sign up Log in
I can't attach files in field on transition screens, I can do it on the creation screen only
Reply Test Group
May 7, 2021 edited
Hi Atlassian Community,
I want to insert some files during a status transition, letting the user to put attachments (in the comment or in some fields like Description or multi-line custom fields) on the transition screen, but this operation seems to be possible only during the CREATE transition..
In the Create transition, if I put the field "Attachment" in the Create screen of the respective issue type, and if I have some mullti-line fields like 'Description' (with Wiki Style Renderer set in the Field Configurations), I see the Attachment option for those fields:
, and if I remove the field "Attachment" from the same Create screen, the Attachment option is gone:
Imagining that I can do the same thing on the transition screens, I created a screen with the field Attachment and some text fields, one of which ( 'Descrizione (US)' ) is a multi-line text field with Wiki Style Renderer (necessary for seeing all the style options, plus the attachment one):
, but in the end, on the transition screen I can't see the Attachment option in the 'Descrizione (US)' field or in the comment section:
Obviously I have all the permissions in the Permission Scheme of the project.
Probably it's normal this situation for the transition screens, but for my needs it would have been perfect to have the same treatment the Create transition got.
In this way I can create custom fields used for attaching files in them during some transition, separating these files from those entered in the system field Attachment, for having a better file managment.
There is some work-around, fix releasing or open bug related to this situation?
Thank you for the help,
Fabio
Juan Manuel Ibarra
May 7, 2021
Hi!
It is a common problem, in this article is the explanation of that issue.
Reply Test Group
Hi @Juan Manuel Ibarra
the article you linked is referred to a Service Desk problem, not to a Cloud one, but I tried anyway the work-around suggested by Jeff Santos..
The difference here is that I can't see the 'Attachment' option in the comment section (or in any multi-line text field with Wiki Style Renderer) even if I put some attachment BEFORE going to the transition:
In Jira Cloud this trick just don't work.
Anyway, I watched both the tickets JRASERVER-46035 and JRACLOUD-46035 for keeping track of it.
Bye,
Fabio
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
