I cannot see JIRA Accept remote API calls option
Abel Aneiros September 22, 2015
Hi there,
I'm part of the "JIRA Administrators" group in our https://XXXXX.atlassian.net and I cannot see the "Accept remote API calls option"
I would like to know why?
Abel
Nic Brough -Adaptavist-
September 22, 2015
Yes, it's a restricted function that you won't get on Cloud.  The option is switched on by default.
Abel Aneiros September 23, 2015
is it possible to connect to JIRA on the Cloud from my Eclipse using the mylyn connector? I'm trying and I got "No JIRA repository found at location. Invalid URL or proxy problem." I'm using https://XXXXX.atlassian.net as a Server
September 23, 2015
I've not used the connector so I'm not 100% sure, but I suspect you need to use the REST API url, rather than the base of the server! The Mylyn docs should tell you
Abel Aneiros September 24, 2015
I used to work with in-house-hosted JIRA and we used the same URL
September 24, 2015
Hmm. From memory, Mylyn used to use SOAP, which was deprecated ages ago and turned off completely this year. Is the version of Mylyn you're using recent enough to be using *just* REST?
Fred Schroeder
February 2, 2016
sorry I got a licensed local (Server) JIRA on my notebook but the option "Accept remote API calls" which I need to connect MSProject/Ceptah (or MSProject/The Connector) for Synchronisation is not present in the menue "Project Import", "External System Import". Even I have no idea how to link MSProject/Ceptah with JIRA. Is there a guide in the documentation?
Many Thanks for any help
Fred
February 3, 2016
The option was never in the imports, it was in general configuration.  It's been removed from later versions of JIRA as it needs to be on for some of the internal stuff to work now, so there is no option any more.  It's on.
I don't know Ceptah well enough to guide you on that end, what does their documentation say?
