I cannot update the values in JIRA using "Integrate Jira Cloud with MS Excel" add-in
Przemyslaw_Lizurej
June 4, 2025
I cannot update the values in JIRA using the "Integrate Jira Cloud with MS Excel" add-in.
I started using the app in Excel. The JIRA server version allows updating and creating issues.
Does the app version for Cloud support updating the items in JIRA?
Hi @Przemyslaw_Lizurej
The "Integrate Jira Cloud with MS Excel" add-in connects Jira Cloud with Excel for data import/export but doesn’t fully support all features, especially updating or creating issues.
Following are points to be considered:
  • Permissions: Ensure the user account has permissions to edit or update Jira issues.
  • App Limitations: The Jira Cloud version may only support data retrieval and not direct updates from Excel.
If updating Jira items from Excel is a crucial requirement, you many consider using an Atlassian Partner’s enterprise - grade integration tool, OpsHub Integration Manager (OIM). It automates the syncing of data between Jira Cloud and Excel, ensuring updates to Jira issues can be done directly from Excel without relying on the limitations of the add-in.  It will also take care of the issues like inconsistent data mapping or functionality gaps in the Excel add-in.
Hope it helps!
