I got notified by "Default assignee does not have ASSIGNABLE permission" when creating child issue
annisa.nindya August 20, 2024
Hi all,
I attempted to create child issue/sub-task which showed no troubles before my manager resigned. She was also the one who gave me access to my company's JIRA so I suppose she was the main administrator for this specific channel project.
Normally, when I created child issues or sub-tasks, it will automatically assigned to her account before I alter it to my account. However after her account removed/deactivated, I encounter this kind of notification when I need to make sub-task.
Since she was the sole administrator and now there's no one in the position. What should I do to fix this problem?
Kindly let me know and let's disscuss.
Thank you!
Mohanraj Thangamuthu
August 20, 2024
Hello, Good day. Please reach out to any other "Jira admin" user or "Org admin" user. They should be able to change the project settings >> details, default assignee settings.
If there is no other Jira admin or site admin user. Then please create a ticket with us at https://support.atlassian.com/contact
Hi @Mohanraj Thangamuthu
Thank you very much for the answer. I'll try to find another admin then.
Like Mohanraj Thangamuthu likes this
annisa.nindya August 22, 2024
Hi @Mohanraj Thangamuthu it seems like I couldnt find anyone with access as JIRA admin. To create a ticket, which one should I choose?jira issue.jpg
Also, it seems like to raise a ticket, I need an admin as well.
Thank you in advance!
August 23, 2024
Hello, Thanks for the reply. I checked your site and could see 10 site admins. Please check on your end again.
Rilwan Ahmed
Hi @annisa.nindya ,
Welcome to the community !!
Default assignee is set in two ways.
  1. In the project settings (https://<domain>.atlassian.net/jira/core/projects/<ProjectKey>/settings/details)
  2. In Components section
    https://<domain>.atlassian.net/plugins/servlet/project-config/<projectKey>/administer-components
You need to check in both the options and remove your old managers name. Project admins or your organization Jira admins can do this change.
Hi @Rilwan Ahmed
Thank you for the answer!
Like Rilwan Ahmed likes this
Ollie Guan
hi @annisa.nindya ,
Possible Solutions:
  • Check Permissions: Ensure that the default assignee has the "Assignable User" permission in the project's permission scheme. This permission allows a user to be assigned issues.
  • Update Permission Scheme: If the default assignee does not have the necessary permissions, update the project's permission scheme to grant the "Assignable User" permission to the appropriate roles or groups.
  • Change Default Assignee: If updating permissions is not feasible, consider changing the default assignee to a user who already has the "Assignable User" permission.
  • Project Roles: Verify that the default assignee is included in a project role that has the "Assignable User" permission.
Hi @Ollie Guan
Thank you for the suggestion.
How do we check all of these? Which page should I go to? I have tried to open "Personal Setting" here and others but I don't see anything like these points.
Or, should I become an admin since I am not one of the admin.Screenshot 2024-08-21 121519.jpg
Nikola Perisic
Welcome to the community @annisa.nindya
Look into your Permissions within the project (assuming you have at least project admin permissions - you are in the Administrators role), and look for the Assignable User permission - look into the roles that are under this permission and modify them so you can create the issue.
You also mentioned that there is an automation rule as well. Look into Automations and also the even where your manager was mentioned as the assignee and adjust the changes.
Nikola Perisic
Ah, sorry, I've missed the DEFAULT assignee...
Hi @Nikola Perisic ,
Unfortunately, I think I am not an admin looking at the way I have no access to see Assignable User permission. I am in a junior position here so my tasks is only to create tasks, change its status and when my manager was still here, I have access to change the assignee in child issue and main task. Here is the look of my JIRA account
Nikola Perisic
Hi @annisa.nindya
No worries! We've all been there! I understand your situation. What @Mohanraj Thangamuthu have suggested is something that you can follow.
Like # people like this
