I have created Custom field in Jira Issue, While i create a new issue i am unable to find that field
krishna jaju March 25, 2024
While i create a new issue i am unable to find that field on that layout.
I have associated that field to all the screens available,but can't see that field while creating a new issue record.
priyanka yadav
March 25, 2024
Try searching the custom field in the section where you have added there are multiple sections where you can add your new or existing fields. This will help you to find the newly added field.
GNarsimhagowda - Empyra
March 25, 2024
Hi @krishna jaju  ,
I have attached the screenshot follow these you will be able to find  the field.
If we don t have the field on the screen we will get an error message!
Hey @GNarsimhagowda - Empyra
I cant find this option as find my field.
Is this beacuse i am using a free version of Jira Software?
Check the below screenshot.
March 26, 2024
Hi @krishna jaju ,
Try doing this,
Goto Summary in the project settings
Click on the screen that is been  used in your project check if the issue type is using the same screen or different screen
Once you click on it you will be redirected to screen scheme page again click on the screen
Once you click on it you will get to the screen configuration navigate to the bottom of the screen and try adding that field.
Like priyanka yadav likes this
March 26, 2024
Hope you are the admin of the instance
krishna jaju March 26, 2024
This was helpful but all i had to do is add that field to the layout!
Thank you!
Meet Darji March 25, 2024
Hi @krishna jaju
Would please you check that this field is added to all Create screens if already been added, guide us to where is my field where you can find the exact problem.
I have created a Custom Field called As SF-ID and when i click on show custom fields i cant see that field.
Check the below screenshots,
March 25, 2024
Hi @krishna jaju ,
Try searching for the field in the Top left side of the create screen you have the option as Find my field there you will be able to analyse why the field is not visible.
Thanks.
Hi,can you please guide,where do i check this option create screen?
I don't get this option Find your field.
Check the screenshot.
FREE
