I'll like to sum number custom field in my Dashboards pie graphic
Armando Gomez
July 19, 2022
Looks like the customer number field is not listed as field and it doesnt have the sum property. How can I enabled i?
Marlene Kegel - codefortynine
Welcome to the community, @Armando Gomez.
I am Marlene from codefortynine.
It is possible to show Pie Chart statistics for any number field (also custom number fields) with our Jira cloud app Quick Filters for Jira Dashboards.
Below you can see a screenshot of the configuration menu of the "Quick Pie Chart" gadget.
You can test our app without installation on our demo dashboards.
Trudy Claspill
Hello @Armando Gomez
Welcome to the community.
The built in Pie Chart gadget for the Dashboard does not allow you to specify a field for which the values should be totaled. The pie wedges are based on counts of issues that match the Statistic Type you specify.
It doesn't appear that there is a built in gadget to sum up a custom numeric field. There is a change request for that, and a suggestion for finding third party apps that could be added to your Jira instance in this post:
https://community.atlassian.com/t5/Jira-Software-questions/How-to-see-the-summed-up-value-for-a-custom-numeric-field-based/qaq-p/1749610
