Here is the endpoint I'm hitting:
https://<our_domain>>.atlassian.net/rest/api/3/project/search?expand=description,lead&maxResults=1
Hello @ben.wilen
It appears that the endpoint returns only non-archived, non-deleted projects by default, and since they are live projects it appears to exclude the archived-related fields.
You can search the archived projects by adding status=archived to the parameters.
Adding to this...
The ?includeArchived=true parameter noted by @Aaron Pavez [ServiceRocket] does not work with the /rest/v3/project/search endpoint.
@Trudy Claspill Yep, seeing that and thank you for pointing that out! Just to make sure I'm not missing anything, are there any other statuses besides "active" that can be passed to the URL?
That information is in the endpoint documentation:
You're welcome!
If your question has been adequately addressed, please consider clicking on the Accept Answer button to mark your Question as Solved. This helps others searching the community find posts with validated solutions.
Hi @ben.wilen
Can you check if this works?
/rest/api/3/project?includeArchived=true
The property for that can be found here:
Although the project is deprecated, now we need to use this project paginated:
Regards
Thank you for the quick response @Aaron Pavez [ServiceRocket] !
"/rest/api/3/project?includeArchived=true" returns the archive field, and "/rest/api/3/project" also returns the archive field.
Can you clarify "Although the project is deprecated, now we need to use this project paginated:"...does that mean the recommended method is to use the deprecated endpoint or is there a way to use the "project/search" endpoint and still get the archive field?
