I need help with JQL
Samuel Prathipaty
How to find issues that are created in the last 2 months and are resolved with in their due dates, as well as issues resolved after their respective due dates.
Annu Satpute
January 21, 2025 edited
I am trying to answer somehow its not accepting my inputs, trying again -
Hi Samuel,
You may want to try this -
created >= startOfMonth(-2) AND created <= endOfMonth(-1) AND status = Resolved AND ((resolved <= due) OR (resolved > due))
I hope this will help, let me know.
Best,
Annu | CSM | Amoeboids
January 21, 2025
Hi @Annu Satpute
What you show will not work with Jira Cloud's, built-in JQL features: a JQL statement cannot compare fields in the issue to one another.  It is not a SQL.
There might be marketplace apps to support such comparisons, and they are likely not in the syntax you show.
What is the source of your information for that expression?
Like • 2 people like this
Samuel Prathipaty
Hi @Annu Satpute,
Thank you for your response. However, it's not working; it throwing an error.
Error - Date value 'due' for field 'resolved' is invalid. Valid formats include: 'yyyy/MM/dd HH:mm', 'yyyy-MM-dd HH:mm', 'yyyy/MM/dd', 'yyyy-MM-dd', or a period format e.g. '-5d', '4w 2d'.
Samuel Prathipaty
Hi @Bill Sheboy
Right. Is this achievable through the Enhanced Search plugin?
January 21, 2025
Hi @Samuel Prathipaty
I do not know as I do not use that app / plugin.  Perhaps check with the vendor's documentation to learn if it will help.
Like • Valerie Knapp likes this
Valerie Knapp
Hi @Samuel Prathipaty , thanks for your post.
Please can you share what you have so far and where you are getting stuck? Here is the documentation on how to work with advanced searches in JQL to give you a hand - https://support.atlassian.com/jira-software-cloud/docs/what-is-advanced-search-in-jira-cloud/#Construct-JQL-queries
Best wishes
Valerie Knapp
Hey @Samuel Prathipaty , you could try this
created >= -60d AND resolution != Unresolved and duedate IS NOT EMPTY
^ just to get you started, so this is the list issues created in the last 2 months, where the resolution isn't empty (so they are resolved) and the Due date is also not empty.
If you have this column configuration, including the Resolved (which is the Resolved date) and the Due date, you could do a visual confrontation or export the data to Excel to analyse them.
Hope this helps you.
Cheers
