×I added some new custom fields to the Bug screen. I used the issue layout function to put the fields in the correct sequence but the Bug screen still shows the old sequence.
some of the fields are fixed in the UI - you can generally move around custom fields - what are the fields?
https://community.atlassian.com/t5/Jira-questions/Can-I-rearrange-fields-on-a-screen/qaq-p/216220
Check your Custom Fields, make sure Context enables the project you are working in to have access to those field(s).
