I want to add an attachment from JIRA server to every Task using post function
Prashant Karakanagoudar December 17, 2020
Hi Team,
Can someone please help me to add an attachment using scripted post function?
I used the suggestion in below link and it looks like the attachment is getting deleted after the script execution, how can I ensure the script does not delete the file from the location.
https://community.atlassian.com/t5/Answers-Developer-Questions/Is-there-a-way-to-add-an-attachment-with-automation-on-Subtask/qaq-p/467766
def attachmentManager = ComponentAccessor.getAttachmentManager()
def pathManager = ComponentAccessor.getAttachmentPathManager()
def user = ComponentAccessor.getJiraAuthenticationContext()?.getLoggedInUser()
def bean = new CreateAttachmentParamsBean.Builder()
.file(new File("/appl/jira_shared/test.txt"))
.filename("text.txt")
.contentType("plain/txt")
.author(user)
.issue(issue)
.build()
attachmentManager.createAttachment(bean)
Prashant
mogavenasan
January 3, 2021 edited
Hi Prashant,
Can you try the following code and see if it works.
import com.atlassian.jira.issue.AttachmentManager
import com.atlassian.jira.issue.attachment.CreateAttachmentParamsBean
.author(user)
.issue(issue)
.copySourceFile(true)
.build()
You may refer to https://docs.atlassian.com/software/jira/docs/api/8.5.5/com/atlassian/jira/issue/attachment/CreateAttachmentParamsBean.html for more details on CreateAttachmentParamsBean.
I hope this helps.
Moga
Edited based on the reply. Thanks!
Prashant Karakanagoudar January 3, 2021
Hi Moga,
Thanks a lot for your inputs here.
It worked. :-)
Changes the copySourceFile with Boolean value instead of a string.
Prashant
Like • mogavenasan likes this
SERVER
VERSION
8.5.5
