I want to make two simple text fields required when the value of "Regression" field is set to "Yes"
tomh June 12, 2023
Upon Bug creation:
When "Regression" value is set to "Yes"
Make the fields "Good version" "Bad version" required
Evgenii
Hi, @tomh
If you have ScriptRunner, you can set it with Behaviours.
tomh June 12, 2023
Yes, i am using script runner at the moment and i managed to get it now to make the fields throw an exception when they are empty but for some reason it is also throwing when i add values to the required fields
Here is the code im using:
import com.opensymphony.workflow.InvalidInputException
def issues = issue as MutableIssue
// Field names
def regressionFieldName = "Regression"
def goodVersionFieldName = "Good version"
def badVersionFieldName = "Bad version"
// Get field objects
def customFieldManage = ComponentAccessor.getCustomFieldManager()
def regressionField = customFieldManager.getCustomFieldObjects(issue).find { it.name == regressionFieldName }
def goodVersionField = customFieldManager.getCustomFieldObjects(issue).find { it.name == goodVersionFieldName }
def badVersionField = customFieldManager.getCustomFieldObjects(issue).find { it.name == badVersionFieldName }
// Get field values
def regressionValue = issue.getCustomFieldValue(regressionField) as String
def goodVersionValue = issue.getCustomFieldValue(goodVersionField) as String
def badVersionValue = issue.getCustomFieldValue(badVersionField) as String
// Check if Regression field is set to "Yes"
if (regressionValue == "Yes") {
// Check if Good version field is empty or null
if (goodVersionValue?.trim()?.isEmpty()) {
throw new InvalidInputException("Good version is required when Regression is set to Yes.")
// Check if Bad version field is empty or null
if (badVersionValue?.trim()?.isEmpty()) {
throw new InvalidInputException("Bad version is required when Regression is set to Yes.")
Evgenii
Looks like I understood the problem.
You have to split behaviour in two parts. I made an example. In example imagine, that my field "Self Development" is your "Regression"
Evgenii
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
FormField gvField = getFieldByName("Good Version")
FormField bvField = getFieldByName("Bad Version")
gvField.setHidden(true)
bvField.setHidden(true)
FormField affectedField = getFieldById(getFieldChanged())  // Lets imagine it's Regression CF
def affectedVal = affectedField.value
if (affectedVal == "Yes") {
    gvField.setHidden(false)
    bvField.setHidden(false)
    gvField.setRequired(true)
    bvField.setRequired(true)
} else {
    gvField.setRequired(false)
    bvField.setRequired(false)
tomh June 12, 2023
First of all, thanks a lot for the fast replies!
Where did you use this code? Im using "Simple scripted validator" It looks like you are using some other validator type maybe?
Is that in the custom field configuration?
Evgenii
It's not vaidator. It's behaviour. It's used, for example, to prefill description, on issue creation (and many other cases)
It's located here:
https://your.address/plugins/servlet/scriptrunner/admin/behaviours
You wrote, that on creation you want users to fill required fields - fine, use behaviours :)
How it works - you create new behaviour, map it with needed project and issue type, then add there scripts, which I wrote. That's all, no validators needed.
Take a look, they are very cool in cases, when you want to automate actions, while user uses issue creat/edit screens.
https://docs.adaptavist.com/sr4js/latest/features/behaviours/behaviours-tutorial
tomh June 12, 2023
OMG, thank you, i managed to make it work via script runner behaviours like you said.
Thanks a lot for the help
Like Evgenii likes this
tomh June 12, 2023
All works as expected. Thanks
Evgenii
Well, why not. Let's try zoom.
You need to look at changes of "Regression" field, not "Good version" or "Bad version".
You can log events with log.warn("Something to log: ${resultOfAction}")
