×Hello everyone,
I've been stuck with this question for a while.
To explain, when creating a ticket, I select an insight object corresponding to a "store" and then I would like to use the attributes of this insight object to modify custom fields of the issue.
I would like to do this via a post function when creating a ticket.
Could you help me ?
Kind regards
Hugo DONA
Hi @Hugo DONA,
At the present time, Jira Workflow Toolbox for Cloud does not support Insight custom fields.
However, we are planning on releasing a new feature named Execute remote action that will be able to fulfill your requirement by the end of this year.
In the name of Decadis xApps,
Vicente
Hi @Hugo DONA Is there a reason why you feel this needs to be managed via post function rather than using Jira Automation?
Jira automation is quite powerful and could handle this. You would want to do something like this:
I have access to a tab "automation" I put in place the rules that you have quoted however in returned value I have the string of the smart-value.
Hi Hugo - You appear to be on Jira Cloud which simply uses "Automation" whereas "Project Automation" was specific to Jira Server.
Can you please share a screen shot of your rule?
I just discovered that we have to use the automation rules from the "Jira Workflow Toolbox" plugin, so it is not valid since your proposal. Thanks for your help anyway.
we can't use the smart value but the JWT expression parser :(
