I want to use story points estimation in tempo planner
Tejus J
February 27, 2025
I use Kanban methodology in my project and want to visualize the Capacity and Utilization of the team using tempo planner. What are the ways that I can use this using story points and not hours.
Tempo Support
February 27, 2025
Hello Tejus,
Thank you for reaching out,
We currently have a feature request similar to your inquiry, https://ideas.tempo.io/ideas/T-I-2081
Please add your vote to the idea if you want to receive an update when the status changes.
If you have additional feature you would like to suggest, we encourage you to create a feature request in our idea portal so our product team can consider adding this in the future.
Here is a document with links to the portal and an explanation of how it works: Tempo Idea Portal
Best Regards,
Tempo Support Team
