I have existing jira and zephyr installation and i would like to move JIRA to ondemand model and integrate my exisiting zephyr with the new ondemand jira,
can i do that? and how? how to i open zephyr ui?
Naama
Hi Naama,
What you are seeing is not an error. What this means is that your JIRA instance is available to integrate with. Below is documentation on how to integrate Zephyr Enterprise/Community Edition with JIRA OnDemand:
http://support.yourzephyr.com/product_help/4.5/Administering_Zephyr/Defect_Tracking/JIRA/JIRA.htm
Also what version of Zephyr Community Edition are you using? Are you using 4.5_6967 or 4.5_7195?
Kind Regards,
Emily
Hello Emily,
Can you please let me know if i can use the zephy plugin that i have at the moment (that is integrated with JIRA Installation) or do i need to install a new producut? and i do need to isntall a new product can u pls let me know which one?
The documentation is a bit confusing...
Naama
Hi Naama,
If you are talking about our Zephyr for JIRA product, this product is not compatible with JIRA OnDemand. If you are using OnDemand than you will not be able to use Zephyr for JIRA.
However we offer two other products that are compatible with JIRA OnDemand. Zephyr Community Edition and Zephyr Enterprise Edition. You can read about them here:
http://www.getzephyr.com/zephyr/zephyr_community/overview.php
http://www.getzephyr.com/zephyr/zephyr_enterprise/overview.php
If this does not answer your quesiton please be more specific as to which of our products you are currently using and what version of JIRA you are running.
Kind Regards,
Emily
Hi Naama,
JIRA OnDemand already comes with the Zephyr connector plugin so you should be able to use it following this page.
https://confluence.atlassian.com/display/AOD/Connecting+Zephyr+with+JIRA+OnDemand
Hope this helps,
Marcus
the error that i am getting is the following:
Hi there, this is an AXIS service!
Perhaps there will be a form for invoking the service here...
Thansk
Naama
Hello Marcus thanks for your reply
I saw this page already, i have enabled the plugin my problem is to set the integration from zephyr side,
i have zephyr installed and integrated with JIRA Installation (which i would like to move to ondemand) tried to open zephy admin as the document pointing " http://<your_jira_server>/rpc/soap/jirasoapservice-v2" but i get error on the page
Can you please advise what shoud i do?
Naama
Hi Naama,
What is the error you are getting on screen?
If you can send a screenshot of your screen I may be able to see what we are missing.
Cheers
