I have a specific use case where I want to identify those tickets on which no comment was added by the assignee in the last 24 hours. Is there a way to achieve this using JQL.
If you are willing to consider a third party app there might be one that adds functionality to use in JQL that will help you achieve your requirement.
Are you willing to consider getting an app?
Hi @binay_yadav ,
There was a question similar to yours a few months back, and they used:
Status was NOT "ready for review" DURING (-1d, now()) and created = -1d
See the original thread here: https://community.atlassian.com/t5/Jira-Software-questions/JQL-for-tickets-did-not-change-status-for-24-hours/qaq-p/2530884
I hope this helps,
Michael
Hi @Michael Yaroshefsky - Visor for Jira ,
Thanks for helping out but this doesn't solve my purpose as I want to filter only those on which no comment was added by assignee instead of status change.
Hi @binay_yadav
Sadly you can't. Comment only have two values you can use ~ or !~
Feature request
https://jira.atlassian.com/browse/JRACLOUD-31057
there is a workaround mentioned in the FR. worth trying.
Maybe with a third-party app it's possible.
Regards
