Identifying Active Projects
Emerico Vespucci
Hello. We are looking to identify all 'active' projects in our Jira Server instance, v8.20.17.  We are defining 'active' as a project, which has had content created in the last 'X' amount of days.
Our team was considering the use of REST API or JQL or a combination of both.
I saw the possible use of a database query as well:
Example below.
select
pname,pkey,created as project_createtd,updated as project_updatetd
from
project
where updated <= '2019-10-01T02:15:00.102738Z'
Thank you
Emerico Vespucci
Here's how its done
SELECT DISTINCT i.PROJECT, MAX(i.UPDATED) as Last_Updated, p.pname, p.lead FROM jiraissue i  INNER JOIN project p ON p.ID = i.PROJECT  GROUP BY i.PROJECT, p.pname, p.lead having MAX(i.UPDATED) > '2023-01-01' ORDER BY MAX(i.UPDATED) desc, i.PROJECT, p.pname;
Dave Mathijs
Hi @Emerico Vespucci
The Projects section in Administration lists all project where you can sort by Last issue update. Isn't this easier to identify active or non-active projects?
Emerico Vespucci
Correct.  But I don't see an option to extract to create a list.
SERVER
