If I add new sub task issue types to a project why are they not visible
showkat ally March 6, 2013
Hi
I added new sub task issue types to a project but they are not visible in edit mode, but are available in
the move/migrate issue screen. Is this a requirement in Jira.
Vishnukumar Vasudevan
You can't simply edit the Issue Type of an issue. You have to Move it to another type.
That's how JIRA works.
Christian Czaia [Decadis AG]
March 6, 2013
Sorry but that's not right. As Janet outlined you can chage the issue type but the issue type has to have the same field config (workflow...) and the issue type has to be present as a field on the edit screen...
Cheers Christian
Oh..is it ? I didn't know that and never tried too.
Thanks for correcting me.
March 6, 2013
No problem:-)Trying to revoke my down vote...
codelab expert
March 11, 2013
This is currently not possible in Jira. All subtask must have the same issue type as their parents. But you can have look at the plugin "Structure". It could help you but it is not free.
s
Hi Guys
Tried and even though the subtask has the same workflow and is available on the edit screen. The new Subtasks still do not display.
But if select the Move Issues using the Bulk Operation then the New Subtasks display
Looks like it is a Jira requirement.
Regards
Janet Albion
March 6, 2013
The Field Configuration for the Subtasks must be the same. For example, SubtaskA and SubTaskB are both using "Field Configuration XYZ".
March 6, 2013
HEy,
what do you mean with "in edit mode"? You don't have the option "create subtask" in your issue operations tab (more actions) when viewing an issue?
Cheers Christian
Sorry for the missing detail
If I open an exisiting sub task- select edit - and then attempt to change the issue type field to the new sub task issue type - but the new types do not display except for the original ones.
