Dear all,
If is possible, to configure the details in backlog view? I have some custom fields which I want to see from backlog without having to enter the tickets (issues) directly.
For this you need to go to Board Setting > Select Issue Details View > add the custom field which you want to see from backlog section
Accept the answer if it helps
This should be configurable on 'Issue Detail View':
