When creating a ticket with Automation I get the following error/warning in my audit logs:
Unknown fields set during create, they may be unavailable for the project/type. Check your custom field configuration. Fields ignored -Description (description)
Do I need to add a default value to the description field upon creation or is there a way I can ignore that field completely so it does not alert me in the audit logs as "Some Errors"?
Same problem here. I can add the description field to the screen to make this error go away, but I don't want to add a useless field. How can we get Jira automation to not try to set the description field. It isn't a required field so this should be doable.
