Hello, I hope you are all well.
I am planning to migrate from the Standard plan to the Free plan, but I need to know if this could cause any impact with loss of information in the projects in production, mainly related to cards, their comments, assignments and logs or if I will only lose the features of the Standard plan (which is obviously expected).
Thank you in advance.
Hello @Webert
You might find this information helpful. It talks about the functional differences between the Free and non-Free Jira plans.
https://support.atlassian.com/jira-cloud-administration/docs/what-is-the-free-jira-cloud-plan/
In the Jira native functionality there should not be any loss of data, but there could be loss of data from third party apps.
You're welcome.
If my response has adequately addressed your question, please consider clicking on the Accept Answer button to mark your post as Solved.
