Impediment flag sets resolution
mariefkent September 30, 2016
Has anyone seen this behavior?
Setting the impediment flag sets the resolution to the default selection. This only occurs when the flag is set on the main form, it does not occur when the user sets the flag from the right click menu on an agile board.
Nic Brough -Adaptavist-
September 30, 2016
Yes - I suspect you have put the "resolution" field on the edit screen.  You need to remove it.
Thanks Nic.
