Import a project from Cloud to selfhosting JIRA
Aiden August 10, 2015
Hello everybody,
i have a backup file of JIRA cloud.
JIRA version = 6.5 OD 08-001, Java version 1.8.0_45 =
How can I import it in my self hosting JIRA (6.4.6)?
Please help.
Best regards,
Sven
I am a beginner in English language
Paula Silveira
August 10, 2015
Hi Sven,
You can refer to Restoring a project from JIRA Cloud to JIRA Server .
Thanks and regards,
Paula Silveira
Aiden August 13, 2015
Hello everybody,
thx for help. It works now perfect.
Best regards,
Sven
Jaime S
August 11, 2015
Hi, Sven.
Due to version mismatch, the project migration directly won't work. Instead, you should install another JIRA Server in the latest version, do a full migration from Cloud to this one and then export project from this one to your destination instance.
This procedure is described here (the link Paula sent you):
https://confluence.atlassian.com/display/JIRA/Restoring+a+Project+from+Backup#RestoringaProjectfromBackup-ondemandmigration
The two JIRA instances must have the same version, so, you need two JIRA instances in the latest version.
Jaime Kirch da Silveira
Atlassian Cloud Support
THX for the fast support.
But what JIRAversion(Server) do I need for an import?
https://confluence.atlassian.com/display/JIRAKB/JIRA+Build+and+Version+Numbers+Reference
Paulo Junior
August 10, 2015
Hi Sven,
Unfortunately, Cloud instance doesn't support "Project import". Said that, to have it achieved, you would have to set another JIRA instance and then perform a project export from this JIRA  to your main JIRA.
You can use the following document as reference. Please note that you can skip the last step, as you will not be migrating to Cloud.
https://confluence.atlassian.com/display/CLOUDKB/How+to+merge+two+JIRA+Cloud+instances
Cheers.
