Import data
Francisco Navarro
Dear community,
Do you know of a method to "import" data to a drop-down list field?
I have a column in an Excel file with more than 300 items that must go into a list-type field. How can I add them all at once? Do you know of an import method?
Valerie Knapp
December 25, 2024
Hi @Francisco Navarro , thanks for your question.
Here is a knowledgebase article which explains a solution for this https://confluence.atlassian.com/jirakb/how-to-bulk-import-custom-field-values-for-certain-types-of-custom-field-827123935.html
Basically, you need to create some dummy issues which you can then delete but it's possibly faster than manually entering 300 options, especially if you already have the CSV file ready.
Hope this helps you.
Cheers
Francisco Navarro
thank´s a lot Valerie¡
Like Valerie Knapp likes this
