Importing csv datei to Asset
Jardel Kenne July 11, 2024 edited
hallo , i have a small issues that i dont really understand , i am trying to import a list of Laptop local ( excel ) to my cloud . But After doing all the import step and the mapping withe the field , i realized that the import was to quickt and didnt pick any information to the field . I am just getting all the attibuts field , without the informations or the value insside .
Pavol Gočal
July 11, 2024
Hello @Jardel Kenne
could you please share example of the CSV file and your mapping to the Asset Object in import configuration?
I would also suggest to check "More options" in import structure, where you define delimiter.
import structure.png Check if it is the same as in your CSV.
I did it and got this steps after where i had to maps with the field , then after i got no informations2024-07-11 13_52_36-Objektschemakonfiguration - Jira – Mozilla Firefox.png
so after importing i thought i will get a complete field and Object  with the informations but not
Pavol Gočal
July 11, 2024
Can you please share first few lines of your CSV? With headers and values.
Pavol Gočal
July 11, 2024
Seems good. Try saving the file as CSV, not TXT and then import.
