I have been trying to import a CSV file into an Insights Object. I can update all fields except where the field is an Object (the list comes from another object). How do you do you update this field when importing?
Hi Alvin. If the values for the other object are not defined in that object type already, you need to create a separate mapping for that. You can take a look at this other post with example:
https://community.atlassian.com/t5/Jira-questions/How-to-update-Insight-Objects-that-have-fields-that-reference/qaq-p/1992481
Hope this helps.
Thanks. I did not create the mapping. Once I updated 'Object mapping (IQL)' field to map to my object I was referencing it work.
Thanks for your help!
