Hi @Paulina Mijal ,
CSV import is a builtin feature provided by JIRA. Take a look to the following article https://confluence.atlassian.com/adminjiraserver/importing-data-from-csv-938847533.html
Hope this helps,
Fabio
Hi Paulina,
Import issues using CSV would be the more preferable option. For this,
For example, this is valid:
Summary, Assignee, Reporter, Issue Type, Description, Priority
"Test issue", bob@example.com, bob@example.com, 1, ,
For importing the file to Jira:
You can visit this link: https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
