Importing issues in CSV - JIRA CLOUD
Helene Saverot October 9, 2019
Hello !
Can you please confirm me that, if I import issues with a csv file on JIRA CLOUD :
> previous projects and issues won't be deleted
> the imported issues' project has to be set before I import ?
Thanks for your help !
2 accepted
Dario B
October 10, 2019
Hi @Helene Saverot ,
As mentioned in the importing data from CSV documentation page, when importing from CSV you are actually importing issues only into one of more existing projects.
Therefore, the answer to both questions is yes:
  • Previous project and issue will indeed not be deleted. You will only add more issues to one or more existing projects
  • You can only import issues in one (or more) already existing project(s). Therefore yes, the project has to be created before importing the issues from CSV.
For details please review the below pages:
I hope this helps.
Dario
helene-externe.saverot October 10, 2019
Thanks for your help, it's perfectly clear :)
Dario B
October 10, 2019
You are very welcome @Helene Saverot ! :)
If you found it useful, please spare some time to accept my answer so that the question will be marked as answered.
Have a nice day,
Dario
Helene Saverot October 15, 2019
Done :)
Like Dario B likes this
