  • Community
  • Q&A
  • Jira
  • Questions
  • Impossible to change context filter in Greenhopper 5.10 planning/task boards - always jumps back to Default context
Patric Westberg
May 28, 2012
JIRA 5.0.5, Greenhopper 5.10:
When looking at the Plannning board and trying to change context, Greenhopper thinks for a while and then jumps back to the "Default" context. This makes it impossible to change context - very annoying indeed...!
Nicholas Muldoon
May 29, 2012
Hi Kel,
You can track progress here:
https://jira.atlassian.com/browse/GHS-5258
It is in QA right now, expect a release later today if all goes well.
Thank you,
Nicholas
Kelly Arrey
May 29, 2012
Super ! Thanks !
Kelly Arrey
May 29, 2012
Back up and running. Thanks again.
Kelly Arrey
May 29, 2012
Thanks Nicholas, can you give any indication of what shortly means.
Nicholas Muldoon
May 29, 2012
Patric, David,
This is a bug in 5.10. We are fixing the bug as I write this and we will release a 5.10.1 shortly.
Thank you for your patience.
Nicholas Muldoon
Kelly Arrey
May 29, 2012
Thanks Nicholas, can you give any indication of what shortly means ? Are we talking hours, days or weeks ? Thanks,
David Bolton
May 29, 2012
We're having the same issue. Very frustrating.
