In Advanced Roadmaps (Data Center) I can't move 2 orphaned Epics (TMS-3711 and TMS-3622 in the attachment) up under their parent Initiative (JIRA 9.1.0). I've included a screenshot. The orphaned Epics, as shown, will go under "any initiative above" except its rightful parent "TMS-3247". When we attempt to move it under Initiative TMS-3247 it stays shaded red (no-go). I think I have asked this before but am trying again with a screenshot as I am completely out of ideas. Something is wrong with that Initiative. I have re-imported it in from our Prod system again thinking it was corrupt somehow. We are using Adv Roadmaps as a POC to leadership to show its potential and can't have this happening.
Any help/suggestions are greatly appreciated.
Best,
-Steve Josu
Hi @Steve Josue - This is odd. I would try a couple things:
Hi Thank you for your reply:
1) I'll have to figure out how to do this.
2) Yes, I tried all the available states, no change. Again, all the other Initiatives have no issues and lots of children. This initiative has none (but should have the two I referenced).
3) Oh yes, I tried that. But no matter what I type in the parent link field it persists with "no match found" ....as if it wasn't ever looking in the first place. I will look into your #1 item.
Best,
-Steve
One other thing to try... I've never seen it myself, but maybe the issue type field is corrupt on that particular issue for some reason. Are you able to change the issue type to something else and change it back?
Great idea didn't fix, I am at a complete loss here.
This one may be an issue to raise with Atlassian support unfortunately. I can't think of any reason why this would happen with one issue.
As a workaround, maybe you can just clone that issue and re-link all the children to the clone.
I actually re-exported the Initiative from Production and Imported into our TEST system with no change. Crazy! I was thinking sometimes Atlassian monitors this board (I think) and was hoping maybe they could chime in. I'll try to generate a ticket. Thanks for all your help on this!
