Would like to add our Jira Project in Confluence.
I know I can add a blank page and then add the Jira project link in my page.
but..
Is there a way I can directly add the Project to the tree so that when clicking on the JIra Project page it directly opens my Project? Instead of having to select my Project page and then having to select the link which will then open my Jira Project?
I have the same question in regards to KanBan Board, I would like to add a KanBan without having to actually add the Kanban Link to a page.
Hello @Laurie Greener
I don't know of a way to embed a JIRA link directly in the Pages tree. It is, after all, a tree for displaying Confluence pages, not other types of links.
However, you can add links to the Shortcuts section of the navigation pane.
tks yes I was aware of those options was hoping was able to just add a direct link
Save your spot
