In GreenHopper 6, can I create subtasks that inherit field values from the parent task?
Deleted user January 30, 2013
In the Classic Boards, if I create a subtask within GreenHopper (using the "cog" menu, Add Sub-task), some of the fields (Assignee, Component, etc) are prepopulated with the partents values. This is usually desirable and can save a lot of time.
However, in the GreenHopper 6 boards, the equivalent action does not provide these prepopulated fields. There are some, like reporter, that default to the user doing the action, but not Assignee, Component, etc.
Is there a way in GreenHopper 6 to get this old behavior back?
Thanks.
Tom
dleng
January 31, 2013
Seems liek a feature request: https://jira.atlassian.com/browse/JRA-5225
As described by other users in the feature request, there are some workarounds, such as the Minyaa Suite plugin: https://marketplace.atlassian.com/plugins/jira.plugin.minyaa
Or the JSS plugin: https://plugins.atlassian.com/plugin/details/16346
Within the project Workflow, navigate to the the "Create Issue" transition (first transition in a workflow under Open), then add a JSS Post Function script to copy whatever fields you require
if (issue.getParentId() > 0):
 	issue.setComponents(issue.getParentObject().getComponents())
 	issue.setFixVersions(issue.getParentObject().getFixVersions())
 	issue.setAffectedVersions(issue.getParentObject().getAffectedVersions())
 	issue.setPriority(issue.getParentObject().getPriority())
Deleted user January 31, 2013
Thanks Daniel,
I'd searched around using various keywords and wasn't able to find this myself, but this is useful. I voted up JRA-5225 and am watching it, and I will investigate your suggested workarounds.
Tom
atlassian, team ’25 europe, virtual access, catch team 25 virtually, anytime anywhere, hybrid event, atlassian conference, atlassian learning, ai teamwork, remote attendance, digital access pass, keynote livestream, product announcements, community events
Register for free Team '25 Europe digital access
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
Upcoming Jira Events
