I created a few issues on 07/May/2021, and try to get by following JQL. But I didn't get those issues.
created = "07/May/2021"
Hi @Piyush Patel ,
Keep in mind that if you put a specific date it means 00:00 of the day as well.
You could try ">" and "<"
also be sure to keep the correct format for your system language.
For me for example i need to put yyyy-MM-dd as my format.
So you could do
created >= "2021/03/07" AND created <= 2021/03/08
I believe this should give you all the issues created during the day of 7/Mar/2021
Hi @Piyush Patel the problem here is that created date stores Date and Time. So if you want to use "=", you need to put date and exact time to the condition. So the correct and easiest condition is created >= "2021/05/07" AND created < 2021/05/08
I believe the following request should work for you:
created >= "2021/05/07" AND created <= "2021/05/08"
The other option I can recommend is the Dynamic Filters: JQL Replacer add-on. It allows you to set queries without JQL knowledge.
For your query, you can choose created within thee last 1 day as shown below:
Or set the dates you need from the drop-down calendar:
Hope you find this info helpful.
Best regards
Register today
