In Progress issues visible in Scrum backlog
Robert Yocum May 6, 2020
I have a project that shares a kanban board and a scrum board. Items that are in the In Progress status category in the Kanban board are visible in the Scrum board backlog. How do I setup a filter so that the Scrum backlog shows only items that are not in progress?
Telmo Fernandes
October 14, 2021
Hi Robert,
On Board Configuration > General > Saved Filter > Edit Filter Query
try something like :
project = <your project name> AND (status in (Backlog) OR Sprint is not EMPTY) ORDER BY Rank ASC
This way on all the board (both "backlog" and "Active Sprints", you'll only see items that are either in BACKLOG status or that belong to a sprint, no worries, items that are in closed sprints will not show up)
Try that and check if it works.
Best Regards,
Nic Brough -Adaptavist-
May 6, 2020
What are the column setups and board filters for each board?
Kanban board:
category = "Equity Management" ORDER BY Rank ASC
Scrum board:
category = "Equity Management" AND ("Stakeholder Team" != Strategic OR "Stakeholder Team" is EMPTY) AND issuetype not in (hotfix, escalation) ORDER BY Rank ASC
