when I assign a lead under Projects/Components ONE(!) User ist listened many times. Other Users are shown correctly one times. Anyone have a suggestion, why? Or its a bug? Thanks for help!
- Chris
Try to make bloking reindexing at first. Maybe it helps
How can I do that? Dont find the settings for that. ThankX :-)
Here is an instrustion: https://confluence.atlassian.com/adminjiraserver072/search-indexing-828788115.html
Note, that while blocking reindex jira will be unavailable. Time depends to number of issues, projects and custom fields.
It is better to perform it into not working time.
Hi, Unfortunately, the problem was not solved by your suggestion. Another idea? TnakX :-)
Could you check into user manager do you have only one user with this name?
I have checked this many times, there is only one user, imported from our ActiveDirectory
It semms to be a bug. You should report it to Atlassian.
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
