In jira portfolio: is it possible to only show epics/ stories from the current sprint?
Jeroen Thoelen
while using portfolio for Jira, it's performance is very slow and takes a lot of time to work with because of the large amount of epics/ stories in scope.
Is there a way of only showing the epics/ stories from the current sprint or next sprint and work with these?
This will increase the performance I think...
Thank you,
Jeroen
Gabriele Franck
September 3, 2018
Hey, Jeroen
In Portfolio, when you're creating your plan, there is a setting called Issue Source, which you can edit the issue sources for your plan at any time.
In your scenario, you can select the board you're working on and after that select the issues that belong to the current/next sprint respectively.
This doc Configuring issue sources can provide you more details.
