I am using Jira 6.1. Currently, on every card, it shows the remaining time estimate.
The work ratio is calculated in place when it is part of a report or display where it is needed.
To get it on a card, the easiest method is probably to write (or script) a field that calculates and displays it, and then include that on the card definition.
Can you please help me in scripting if you had worked on it? I am not much aware of the scripting part.
