Include the automation trigger field in Slack message description
Fouad El-Gendy
I have an automation which sends a slack message when any of given fields (shown in attached screenshot) gets updated.
Is there a way to include the specific field that triggers each automation in the message? Instead of just a vague "Issue X has been updated."
Ex: If the Description of an issue is updated, I'd like the Slack message to say 'The Description of story X has been updated',.. same thing for any of the other fields
Kalyan Sattaluri
May 21, 2024
Hello @Fouad El-Gendy
You can use the smart value {{fieldChange.field}} to reference the field name which was changed.
If you want to reference the values which were changed... you can look at the below link for available options. Hope it helps!
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#:~:text=issue_updated%20%3Aissue_commented.-,%7B%7BfieldChange%7D%7D,-Available%20anywhere%20smart
Fouad El-Gendy
Works like a charm, thanks a bunch for the great help @Kalyan Sattaluri
Like Kalyan Sattaluri likes this
May 21, 2024
Hi @Fouad El-Gendy
Adding to Kalyan's suggestions:
Not all issue changes trigger the Field Value Changed trigger (or the generic Issue Updated trigger) and so not all of them are detected in the {{fieldChange}} smart value for Jira Cloud...even though those changes appear in the issue change history when viewing an issue.
Some of these gaps are apparently due to errors in changelog handling (e.g., list fields such as Fix Version and Sprint), while others appear to be automation design choices where there is a separate trigger to detect changes to some fields.
I recommend testing for each field you wish to track to confirm they are detected as you need.
Like # people like this
Kalyan Sattaluri
May 21, 2024
Thanks Bill. I keep forgetting to warn people of this behavior you have mentioned previously. I will try to clarify/state this point go forward!
Like Bill Sheboy likes this
Fouad El-Gendy
Indeed Bill, I did check and they seem to work just fine, thank you for pointing that out!
On another note, I did create a separate automation to send any updates to the comment section of specific issues, so yeah, there's that.
