Hello
i have created one "incoming mail server" and one "mail handlers"
You need to know i have access to 3 projects with this "keyproject":
- TES
- TEST
- TEST2
so now i would like to create issue from email create issue in the project "TEST" so i have insert in the subject mail " [TEST] - Hello Hello"
body mail :
this is test
and the issue don't created you know why ?
Thanks in advance
When you setup the Mail Handler there is an option to Test the Conn, does that show any imported mails?
Also, if possible can u share the details of your mail handler setup? If you can share some images we could help you figure out if the Folder path is configured correctly?
