Indexing in a virtualized environment
Adam White June 12, 2016
For those of you that have virtualized your instances (both application and database), what are your indexing speeds like / how many issues do you have?
Ours seems to vary wildly. We have ~80,000 issues and a background index takes a widely variable amount of time.
MattS
June 16, 2016
Background index times depend on the activity in JIRA at the same time. I'd check your VM server statistics for other VMs using resources (CPU/disk) during the same time. You also want to check you have enough -Xmx set for the JVM heap to avoid large GC pauses
Adam White June 16, 2016
Our  XMX value is "-Xmx6144m", so that seems like plenty, no?
The database server has 4 Cores and 18GB RAM. MS SQL Server 2012.
Boris Georgiev [Appfire]
June 16, 2016
What type of database are you using and what version (very important as I noticed great difference between MySQL versions for example) ?
Indexing speed might be affected by a lot of factors.
Peter T
June 12, 2016
Hi Adam.
I would look at the storage performance.What are you using to provision storage to the VM?
On system I use quite often with 50K issues background indexing takes about 8 mins.
This KB Article explains how to start about performance troubleshooting.
https://confluence.atlassian.com/kb/testing-disk-access-speed-for-a-java-application-818577561.html
Peter T
Adam White June 13, 2016
We've got raided SSDs providing storage to the DB, Machine, and Home Directory servers, something else is amiss here. Mind sharing your virtual machine specs?
Peter T
June 13, 2016
Can you provide some examples of the times you are experiencing? Also what kind of monitoring you have on the system, CPU, I/O, memory, users load?
Thanks Peter. We have 24GB RAM with 8 Cores. We're using RAID'ed SSD drives for storage. Anti-virus should not be a factor on the machine. The 5 hour background index was on off-hours (sunday afternoon).
We have 90,000 issues and a background index on sunday afternoon took over 5 hours.
We have  323 custom fields according to System Info, could that be a reason? I've tried to restrict some of them to specific projects, but I still have some room to go there. What is your custom field count at?
I should also say that general JIRA usage is very fast, including searching. The only painful thing is re-indexing.
