Indexing is currently not configured
Larry Eisenstein September 14, 2014
I tried to add the Pie Chart to a JIRA Dashboard, but I get the message:
"Indexing is currently not configured so no issue searching can be performed. Please contact your administrator to get indexing configured."
When I go to the Indexing tab, everything is set up and I even had it do an index (172ms since this is a new site).
But, I still get this error on my Dashboard.
Benito Picarelli
October 20, 2014
Hi all,
This was a bug regarding JIRA Charting Plugin which should be solved already per: https://ecosystem.atlassian.net/browse/JCHART-458
Please update your plugins to version 1.26.1 to fix it.
Cheers.
Jay Douglas
October 27, 2014
+1
Deleted user October 19, 2014
Having the same issue on Resolution Time gadget on server not cloud, how to solve this?
Daniel Perez
October 16, 2014
Having the same issue here with Attlassian on demand.
 Trying to re-index did not help. Any idea about how to fix this?
Larry Eisenstein October 1, 2014
I'm not sure what fixed mine, but here is what I know happened.  Maybe this fixed it, maybe they booted my server without me knowing???
  1. My Administrator gave me Administrator permissions
  2. I still had the problem until I removed and re-added the Pie Chart
Deleted user October 1, 2014
I got our JIRA fixed. It's a bug and just takes about 15mins to fix smile They booted our Cloud JIRA and now it works.
Darian Cabot
September 25, 2014
Also seeing this issue when adding a 'Time to first response" chart.
Deleted user September 24, 2014
same here
Sebastian Wagner
September 19, 2014
+1. having the same issue
Elisa [Atlassian]
September 14, 2014
Hi Larry,
The indexing feature can be disabled in the database. Though, we will need a little more investigation. Please open a SAC ticket (support.atlassian.com) under JIRA OnDemand and we will gladly investigate and fix that for you. If you could, please, add the URL to this question on the ticket as well.
Please let us know if you have further questions.
Cheers!
Register today
