×Hi All,
I have been going through various sites and tried to replicate what the same solutions, but have not been able to get the rule to work.
I have Epics populated, I want newly created tasks to inherit the some fields from the Epic like "Reporter", and subsequently I want newly created subtasks to inherit the fields from the Task.
The rule runs successfully, and I don't see any errors, but the fields are not being populated.
What is wrong or how can I troubleshoot where the error is?
I changed the trigger to manually try to check where is wrong, but it doesn't seem to work still.
Thank you!
Hi Amanda ! Welcome to the Community.
Verify also if the fields that you want to populate must be on the Create Screen of your tasks and sub-tasks.
Hi Amanda - Welcome to the Atlassian Community!
Can you share a screenshot of the details of the Edit Issue actions? Basically you want to copy from the Parent
