Using behavior validation script for inline field/s (server side) i need to send error message to user when validation fails
solution founded using screen here
releaseDateField.setError()
releaseDateField.clearError()
Is there a way to send message without using a screen ?
KR,
Ramonde
No, behaviour server-side script can only run in the create, edit or transition screens.
Normally, when you add a field to the behaviour fields's configuration, that field's inline edit becomes disabled and will automatically open the full edit screen. This way, your validation rules will always be enforced.
