Insight post function in jira cloud
Baris Sehitoglu
Hi everyone,
So I have created an insight custom field called Sap Streams & Modules and I want to Select an object attribute which in this case is "global Key users" value of a selected object and set it to another target custom field ( approvers)
This can be done in Jira Server with Set a Jira custom field with the attribute value from a selected object but i couldn't figure it out how to do it in Jira cloud ? any tips ?
thanks a lot
Baris Sehitoglu
I was able to solve it and leaving this as a reference here2022-04-26_12-31-38.png
Dirk Ronsmans
April 13, 2022
Hey @Baris Sehitoglu ,
On Cloud the Automation is highly linked with Insight so you could use that.
You could set a trigger on that field changed and then use the Edit issue action to set the attribute to the field.
Setting the field itself (and getting the attribute) is most likely the easiest using a smartvalue.
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-insight/
Baris Sehitoglu
Can you put a screenshot if possible with the trigger ?
Dirk Ronsmans
April 13, 2022
Sure, if you create an automation rule you can choose the following as a trigger.
So if your insight custom field is changed you can choose that field here and set the action to "edit issue" when that is changed.
Baris Sehitoglu
Hi
