Instance health check warnings
ALLA ATCHYUT KARTHIK June 7, 2021 edited
we have two instances  both the instances have same configurations but in one instance it is showing instance health check warnings. we are useing the same configurations for both the instances. Please find the attached screenshot for reference
Nic Brough -Adaptavist-
June 7, 2021
Your systems are no "configured the same".   Either the proxy or the service behind it are configured to use the outdated protocols.
Check the system settings and the proxy settings.
Olga Videc
Hello @ALLA ATCHYUT KARTHIK
Are both instances on the same host?
Basically, it's a warning that you are using outdated HTTP protocols.
You need to pass this to your "system admin" the person who is in charge of VM maintenance
he will know what to do, just pass his this ;)
https://confluence.atlassian.com/jirakb/health-check-modern-http-protocols-996647804.html
BR, Olga
we are having 2 instances(pp pod1 and pp pod2) with same haproxy and rv configuration but why are we facing issue only on one instance.
Olga Videc
To fix this your system admin need's to configure your instance.
He should follow these steps.
BR, Olga
