Integrate Testrail with Jira
Gnanabaskar
How to configure and integrate Testrail in Jira Cloud. Not sure how to start with the configuration.  Testrail.jpg
Thanks - Baskar
Ste Wright
Hi @Gnanabaskar
Assuming you've installed the Marketplace App, TestRail Integration for Jira, have you tried using the TestRail Integration Guide?
See it here: https://www.gurock.com/testrail/docs/integrate/tools/jira/cloud/
Ste
Shanu Mandot April 22, 2022
@Gnanabaskar
As mentioned by @Ste Wright , you need to input your TestRail instance URL in the address field and generate an API key in TestRail and use it in the next field.
In case of any other issues/queries, you can contact our support team directly by emailing us at contact@gurock.com.
Shanu
Learn more
