Integration Jira X Trello
Glauciely Oliveira De Santi
I'm trying to integrate JIRA and Trello to copy all cards created on Trello to JIRA board.
Who knows how to do this?
10 votes
Andreas
April 5, 2018
Have a look at Trello Sync for Jira.
Trello Sync for Jira app synchronizes data between Trello and Jira. Using different configurations, you can connect your Jira project to Trello board or your Trello board to Jira project. You can also set full synchronization between Trello and Jira (two-way synchronization).
I will see this. Thank you.
Like manuelgeek likes this
Andreas
April 6, 2018
I'm glad I could help.
If this add-on should suite your requirements, mark my answer as solution, so others can see that this question is resolved.
I'm using the cloud version and this addon is available only to server.
Are you know a cloud version to do this?
Like eugene ogongo likes this
Orbicode LTD.
You can use The Jira Power-up on Trello, that allows you to:
  • Link Jira issues to cards, connecting different teams across your organization.
  • View important issue information on the detailed card view.
  • See if your linked issues are done at glance (from the front of the card)
  • Automatically links the Jira issue back to a Trello card so everyone in your team knows how something came to be.
  • Quickly jump to your Jira project by creating a link on your board.
The limitation is that if you want to track status of the tasks you should be login in both Trello and Jira.
Like # people like this
Rebecca Rhoads
July 31, 2018
If you  want to do a simple import of your Trello Board to Jira. Do the following:
Go to the Jira home screen > Settings > System > External System Import > and select Trello
2 way sync is now available as an "Add on" in the Jira Software Cloud when I tried in July 2018! Thank you Jira.
However, Workato, the company who provides it, allows only 100 transactions per month, which is basically nothing if you have more than one project/Trello board. Next level up is $25/month for 5,000 transaction per month.
OR, you could try using Ultimello, who also provides a 2 way sync, but for cheaper: $10/month. I haven't looked into their fine print yet.
Tiina Pajulampi
December 19, 2018
Hi Rebecca, et. al.
I'm not the technical person, but it seems that the workato jira-trello sync only syncs new cards between the applications, is that right?  Would I need to do additional setup, e.g. create new recipes, to get actual syncing of card information, once they exist to go from JIRA to Trello, and vice versa?
Thank you!
Tiina
Like Rajiv Chandrabhanu likes this
Bruna Junckes Sant Anna
I could not find a way to sync both ways, the link at @Andreas is not working.
I wanted to sync everything, including lists, cards, checklists, custom fields, comments...
but could not find at all..
anyone find out how we do it?
Like lautaro Antriolo likes this
Capi [resolution]
Try Unito.io
Yann Pichot
December 2, 2019
How could i Sync multiple trello board in to one jira board ?
What i need is a system that when someone add a card in one of my Trello board, it will be automaticaly add to my jira's board.
Thanks in advance :)
Erik Jimenez
July 9, 2020
Ignacio Pérez
July 23, 2019
I'm having some problems with the two ways integration. It's only working in one way.
Can anyone help me?
webuildersdev
June 4, 2019
it is possible to integrate jira tasks to trello also from locally hosted jira or it does work only with cloud hosted jira projects ?
Regard
Jan
