Most of the internal gadgets title are appearing as __MSG_gadget.xxxxxxxx.
I could see below errors in the logs (JIRA 7.10.1)
WARN [o.a.h.impl.auth.HttpAuthenticator] NEGOTIATE authentication error: Invalid name provided (Mechanism level: KrbException: Cannot locate default realm)
WARN akshatha 824x269x1 /plugins/servlet/applications/versions-licenses [c.a.u.application.marketplace.ApplicationMarketplaceQueriesImpl] Marketplace product query failed: com.atlassian.marketplace.client.MpacException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Would be helpful if I get suggestions on how to debug.
Hi @Akshatha ,
this is most likely because you are using a SSL certificate that is not trusted by the JVM. You need to import it by following this documentation : https://confluence.atlassian.com/kb/how-to-import-a-public-ssl-certificate-into-a-jvm-867025849.html
Let me know if this helps,
--Alexis
Hi Alexis,
JIRA is being accessed as HTTP and not HTTPS and is installed as a service from a Installer which runs with its own jre.
Will the above solution still be valid?. If yes please could u let me know how google.com:443 can
replaced with Jira ip address (12.2.21.9) and running on port 8080 in below command (referring to the link provided).
openssl s_client -connect google.com:443 -servername google.com:443 < /dev/null | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > public.crt
Hi @Akshatha ,
if Jira is accessed with HTTP, then you probably have an issue in your configuration because it looks like it's expecting HTTPS.
Do you want HTTP or HTTPS ? I'm not sure what you are trying to achieve.
I want to access JIRA with HTTP protocol. Please could you let me know where I can expect the configuration issue?
Present JIRA (which is facing gadget issue) is installed in linux server using installer and running as a service, I tried installing a new JIRA instance on a different location o different port in the same server, the new vanilla JIRA instance also has same issue.
Hi @Akshatha ,
can you show me the content of your server.xml file ? It should be located in the atlassian-jira-software-xxx-standalone/conf/ folder. This way we can have a look for any errors in the configuration.
Hi Alexis
Below is the server.xml
<Server port="8005" shutdown="SHUTDOWN"><Listener className="org.apache.catalina.startup.VersionLoggerListener"/><Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on"/><Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/><Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/><Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/><Service name="Catalina">
<!--...--><Connector port="8080" maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false" maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443" acceptCount="100" disableUploadTimeout="true" bindOnInit="false"/>
<Engine name="Catalina" defaultHost="localhost"><Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true"><Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true"><Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction" factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/><Manager pathname=""/><JarScanner scanManifest="false"/></Context></Host><Valve className="org.apache.catalina.valves.AccessLogValve" pattern="%a %{jira.request.id}r %{jira.request.username}r %t "%m %U%q %H" %s %b %D "%{Referer}i" "%{User-Agent}i" "%{jira.request.assession.id}r""/></Engine>
</Service>
</Server>
Can you check your logs and look for lines starting with ERROR ? The one you attached on your first post is only a WARNING and might not be related to your issue
I have attached errors i could find in catalina.out.
I tried running JIRA in safe mode but still the issue exists.
2019-11-13 06:31:08,539 Caesium-1-2 ERROR ServiceRunner [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] Response from 'http://xx.xx.xx.xx:8085/rest/jira-dev/latest/dev-status-pull-changes?sequenceNo=1569230649445&maxResults=2000' has HTTP status '403 Forbidden'. Response:
<HTML><HEAD>^M
<TITLE>Appliance Error</TITLE>^M
</HEAD>^M
<BODY>^M
<FONT face="Helvetica">^M
<big><strong></strong></big><BR>^M
</FONT>^M
<blockquote>^M
<TABLE border=0 cellPadding=1 width="80%">^M
<TR><TD>^M
<big>Appliance Error (configuration_error)</big>^M
<BR>^M
<BR>^M
</FONT>^M
</TD></TR>^M
<TR><TD>^M
Your request could not be processed because of a configuration error: "Account is locked out."^M
</FONT>^M
</TD></TR>^M
<TR><TD>^M
^M
</FONT>^M
</TD></TR>^M
<TR><TD>^M
<FONT face="Helvetica" SIZE=2>^M
<BR>^M
</FONT>^M
</TD></TR>^M
</TABLE>^M
</blockquote>^M
</FONT>^M
</BODY></HTML>^M
2019-11-13 06:41:18,445 Caesium-1-1 ERROR ServiceRunner [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.sal.api.net.ResponseException: org.apache.http.conn.ConnectTimeoutException: Connect to proxy.xxx.xx.com:8080 [proxy.zz.zz.com/xx.xx.xx.xx] failed: connect timed out
at com.atlassian.sal.core.net.HttpClientRequest.executeAndReturn(HttpClientRequest.java:108)
at com.atlassian.plugins.rest.module.jersey.JerseyRequest.executeAndReturn(JerseyRequest.java:131)
at com.atlassian.applinks.core.auth.ApplicationLinkRequestAdaptor.execute(ApplicationLinkRequestAdaptor.java:58)
at com.atlassian.applinks.oauth.auth.OAuthRequest.execute(OAuthRequest.java:58)
at com.atlassian.jira.plugin.devstatus.provider.source.applink.ApplicationLinkDataProvider.getPollResponse(ApplicationLinkDataProvider.java:311)
2019-11-06 17:00:06,923 HealthCheck:thread-1 ERROR ServiceRunner [c.a.t.j.healthcheck.support.GadgetFeedUrlHealthCheck] An error occurred when performing the Gadget feed URL healthcheck
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
2019-11-06 13:36:24,342 http-nio-8080-exec-2 ERROR anonymous 816x2x1 - xx.xx.xx.xx,xx.xx.xxx.xx /rest/capabilities [c.atlassian.instrumentation.Instrument] Unable to snapshot thread local operations (implementation of OpTimerFactory is not a ThreadLocalOpTimerFactory): null
2019-11-06 14:55:39,164 localhost-startStop-2 ERROR [c.a.s.core.lifecycle.DefaultLifecycleManager] LifecycleAware.onStop() failed for component with class 'com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl' from plugin 'com.onresolve.jira.groovy.groovyrunner'
java.lang.NullPointerException
at net.java.ao.EntityManager.putStatementParameters(EntityManager.java:991)
at net.java.ao.EntityManager.deleteWithSQL(EntityManager.java:513)
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.deleteWithSQL(EntityManagedActiveObjects.java:116)
at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects.deleteWithSQL(TenantAwareActiveObjects.java:281)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
... 2 filtered
2019-11-06 15:28:53,416 ThreadPoolAsyncTaskExecutor::Thread 9 ERROR [o.e.g.b.e.i.dependencies.startup.DependencyWaiterApplicationContextExecutor] Expecting state (RESOLVING_DEPENDENCIES) not (DEPENDENCIES_RESOLVED) for context [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.core-plugin, config=osgibundle:/META-INF/spring/*.xml)]; assuming an interruption and bailing out
2019-11-12 17:35:59,037 http-nio-8080-exec-6 ERROR [c.a.j.web.servlet.InternalServerErrorServlet] {errorId=b1628161-afa8-4dad-8274-cc037aaa142d, interpretedMsg=, cause=com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException, stacktrace=com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException
2019-11-12 17:36:52,690 http-nio-8080-exec-25 ERROR [c.a.s.core.lifecycle.DefaultLifecycleManager] LifecycleAware.onStop() failed for component with class 'com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl' from plugin 'com.onresolve.jira.groovy.groovyrunner'
2019-11-12 17:38:52,426 http-nio-8080-exec-2 ERROR [o.a.c.c.C.[.[localhost].[/].[file-server]] Servlet.service() for servlet [file-server] in context with path [] threw exception
2019-11-12 17:35:58,307 http-nio-8080-exec-6 ERROR anonymous 1055x10837x3 1dq37yk xx.xx.x.1xx,xx.xx.xxx.xx/s/-hch7dk/710002/6411e0087192541a09d88223fb51a6a0/7.8.0/_/download/resources/com.atlassian.auiplugin:internal-iconfont-v2/fonts/adgs-icons.woff [o.a.c.c.C.[.[localhost].[/].[file-server]] Servlet.service() for servlet file-server threw exception
2019-11-12 17:35:58,306 http-nio-8080-exec-13 ERROR anonymous 1055x10839x4 1dq37yk xx.xx.xx.xx,xx.xx.xxx.xx/s/daf31ca686a683137da87cefe7cba74c-CDN/-ounpsz/710002/6411e0087192541a09d88223fb51a6a0/7.10.1/_/download/batch/com.atlassian.jira.jira-header-plugin:newsletter-signup-tip/com.atlassian.jira.jira-header-plugin:newsletter-signup-tip.js [o.a.c.c.C.[.[localhost].[/].[file-server]] Servlet.service() for servlet file-server threw exception
Hi @Akshatha ,
you can have a look at . this KB : https://confluence.atlassian.com/jirakb/how-to-fix-gadget-titles-showing-as-__msg_gadget-813697086.html/?_ga=2.73076308.696304845.1573393740-1867168444.1563630283
Also, can you try from the server to call its own url ? You can try this :
Let me know if this works,
--Alexis
Yes I am able to below is the response for the curl command
cur[root@linuxsever logs]# curl -v http://x.xx.x.xx:8080
* About to connect() to proxy proxy.zz.zz.com port 8080 (#0)
* Trying xx.xx.x.xx....
* Connected to proxy.zz.zz.com (xx.xx.x.xx) port 8080 (#0)
* Proxy auth using Basic with user 'username'
> GET http://x.xx.x.xx:8080/ HTTP/1.1
> Proxy-Authorization: Basic MTmnbzQ5MzpTsdteIf0QNDAyMDE5
> User-Agent: curl/7.29.0
> Host: x.xx.x.xx:8080
> Accept: */*
> Proxy-Connection: Keep-Alive
< HTTP/1.1 407 Proxy Authentication Required
< Proxy-Authenticate: NEGOTIATE
< Proxy-Authenticate: NTLM
* Authentication problem. Ignoring this.
< Proxy-Authenticate: BASIC realm="auth1"
< Cache-Control: no-cache
< Pragma: no-cache
< Content-Type: text/html; charset=utf-8
* HTTP/1.1 proxy connection set close!
< Proxy-Connection: close
< Set-Cookie: BCSI-CS-97998adcf3234244d12304=2; Path=/
< Connection: close
< Content-Length: 847
<HTML><HEAD>
<TITLE>Access Denied</TITLE>
</HEAD>
<BODY>
</FONT>
<blockquote>
<TR><TD>
<big>Access Denied (authentication_failed)</big>
<BR>
<BR>
</FONT>
</TD></TR>
<TR><TD>
Your credentials could not be authenticated: "General authentication failure due to bad user ID or authentication token.". You will not be permitted access until your credentials can be verified.
</FONT>
</TD></TR>
<TR><TD>
This is typically caused by an incorrect username and/or password, but could also be caused by network problems.
</FONT>
</TD></TR>
<TR><TD>
<BR>
</FONT>
</TD></TR>
</TABLE>
</blockquote>
</FONT>
</BODY></HTML>
* Closing connection 0
I can see that curl is using a proxy :
You should also configure the proxy in Jira, as described here : https://confluence.atlassian.com/jirakb/configure-an-outbound-proxy-for-use-in-jira-server-247857187.html
And then restart the application. If this doesn't work, you can try changing your /etc/hosts file to point your Jira DNS to the local IP :
127.0.0.1 my.jira.com
Hi Alexis
I guess curl was going through the proxy because proxy details (http_proxy, https_proxy) was configured in /etc/profile.d/proxy.sh. On removing the file, curl command gives below error
[root@linuxserveraks]# curl -v http://x.x.x.x:8080/
* About to connect() to x.x.x.x port 8080 (#0)
* Trying x.x.x.x...
* Connection timed out
* Failed connect to x.x.x.x:8080; Connection timed out
curl: (7) Failed connect to x.x.x.x:8080; Connection timed out
And as mentioned in above blog, I had already configured the proxy in setenv.sh below is the configuration.
JVM_SUPPORT_RECOMMENDED_ARGS="-Dhttp.proxyHost=proxy.zz.zz.com -Dhttp.proxyPort=8080 -Dhttps.proxyHost=proxy.zz.zz.com -Dhttps.proxyPort=8080 -Dhttp.proxyUser=username -Dhttp.proxyPassword=password -Dhttps.proxyUser=username -Dhttps.proxyPassword=password -Dhttps.nonProxyHosts=localhost -Dhttp.nonProxyHosts=localhost"
Kindly let me know if u find error in above configuration
OK so you can try bypassing the proxy by calling the internal IP directly :
change your /etc/hosts file to point your Jira DNS to the local IP :
Hi Alexis,
We have not configured DNS for JIRA, and we are using IP to access JIRA instance (http://xx.xx.xx.xx)
As per your suggestion, i have modified /etc/hosts like below
127.0.0.1 xx.xx.xx.xx and restarted JIRA but issue still exists.
OK so this is actually a network issue, you should ask your network administrator to change the routing so that the Jira instance does not have to go through the proxy to call its own IP.
Hi Alexis
Okay we will check with the network team but if its a proxy call issue then wont that affect on all gadgets. Beacuse few gadgets appear correctly, while few are not.
Some gadgets need to probably call themselves and others not ... but I see your point.
You should try removing the proxy settings in Jira, and ask your IT team to change the network rules so that the server can call itself.
