in the 'Board Insights' section, under the 'Expiration' tab, 'Invalid Date' appears instead of the expiration date that was entered when the ticket was created. Why is this?
I attach the image.
Thank you.
Hi @Utente Test - It seems like you need to reset some fields on the card layout. Can you please go the board settings and look for Layout >> car layout and see what fields are visible there?
bharat
Hi @Bharat Kalia,
thank you for your reply. I checked the card layout and found that the only field present is the due date.
However, in another project, I have these other fields that you can see in the image below, and the due date is still invalid in the 'Board Insights' section.
