Is Gantt chart in Jira depends only on sprint duration?
Neelesh PB December 27, 2022
Suppose, I started a sprint from 20 December 2022 to  28 December 2022.  Later I changed the date of completion of one task under this sprint to 31 December 2022. Will the Gantt chart duration remain same according to sprint duration or will it change to 31 December 2022.
Dave Rosenlund _Trundl_
Hi, @Neelesh PB.  To help you with this question, the community will need to know which Gantt solution you are using.
-dave
Neelesh PB December 28, 2022
Ok Sir.  Thank you.  Let me check it.
Like • Dave Rosenlund _Trundl_ likes this
December 28, 2022 edited
Great. In case it helps, you can probably discover the answer fairly easily by clicking on the "Apps" pull down in your Jira menu — then look for an app with "Gantt" in its name.
There are some that do not include Gantt in the name — but most do.
-dave
