Our support / developer escalation process uses the Zendesk integration. Currently, Zendesk users can see that a JIRA task filed from Zendesk has been started, completed, etc. But, when developers comment on the JIRA task, Zendesk is not notified.
Is it possible to add a hook that executes after a comment is added to a task? This is a concept depicting what I'm looking for:
EscalatedTaskType.onComment(task, newComment) { zendesk.replyToIssue(task.zendesk_issue_id, newComment); };
Chris,
While this is not possible with just the WebHooks, you can use the JIRA Automation Add-On to come up with an automation that automatically transitions an issue when the comment is added and in that transition you can add your WebHook.
But this plugin is not available for cloud JIRA, right?
This would do the trick, thanks! Since posting, I've discovered the Zendesk integrations "Notify Zendesk" button, which works well enough for our org as a means to message back to Zendesk.
